Originally Posted by JRMichler
The big problem with compressed air anything is efficiency.
Have to disagree on this. While efficiency is a problem, the BIG problem is storing enough compressed air to power a vehicle for any distance. People complain about the lack of range of current EVs - 70-200 miles or so on a charge - but a comparable air-powered vehicle might have a 7-20 mile range. And high-pressure storage vessels are heavy: ever humped scuba tanks around?
Now those working examples; air powered tools, torpedos, tunnelling equipment and so on? If you think about it, they're either powered from a central compressor (thus eliminating the need for on-board storage), or like the torpedo, only need to go for a fairly short distance before exploding.
And with tunnelling equipment, you're killing a couple of birds with one stone: you can't have exhaust fumes or sparks underground, and you have to ventilate the tunnel anyway, so you might as well pipe the compressed ventilation air through your equipment...
We need to keep this thread going for the entertainment value.
Agreed :-)
