Old 10-01-2013, 03:37 PM   #44 (permalink)
darcane
darcane's Avatar
Originally Posted by Vman455 View Post
I finally got a chance to revisit this (I've been EOC with key-off since I dismantled the original kill switch wiring, what, last year?). I cut the same wire darcane did, and--voila!--works like a charm.
You're welcome! Much better than Key-Off.
I just did a bunch of work on my Civic and found one little SNAFU. When you pull the engine, you need to disconnect that gray connector and pull it out through the firewall. In hindsight, I would that wire on the cabin side of the gray connector rather than the engine side.
Of course, pulling the engine is rare enough that it's not a major deal either way.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
