Originally Posted by sarguy01
I have an 05 Civic. So all I need to do is wire a relay into the yellow/black wire on the back of the connector to do some EOC cruising??
Yep. It's that easy. And you can interrupt on either side of that gray connector (it just passes straight through). The hard part was figuring out which wire, and that is now done.
Also, change your cabin air filter while you are in there...
Thanks, Jedi, for getting the rest.
