Old 10-11-2013, 05:15 PM   #60 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Bummer about your room mate.
And: next on the list... coolant heater. Recover a lot of your cold weather efficiency loss.
I never bothered with the brake/regen switch mod.
Question though: what happens if you press the switch while also pressing the accelerator? Wouldn't that give you your "regen while driving"? Or does the car watch for accelerator position to prevent 2-pedal issues.
I made much more use of the gears with my Insight when I *wanted* regen -- downshifted often to ensure enough engine RPM so the generator could pump out lots of current. That means it was the first manual car I owned where I often downshifted (matched revs) through the gears while approaching a stop.
