Old 10-24-2013, 12:27 PM   #3 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Not having a MAP value is a problem: The ScanGauge calculates fuel consumption based on AIR consumption; it doesn't directly monitor the injectors.
So if it doesn't have access to air data via MAP... well, Houston, we have a problem.
Just to confirm it isn't a units/conversion problem, I would also try running it in Gallons/Miles mode. I doubt that's the issue, but worth a quick look.
H_RD2 (10-24-2013)
