Old 10-29-2013, 03:53 AM   #68 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by TexasCotton View Post
I started working with this LE from home depot. I did a partial grill block.
Has anyone boiled this stuff in hot water to see if it can be hammered or molding a bit or so.???
I tried a heat gun. Not very effective. I used the curvature built in for the curvature of the airdam. Infact, that curvature offers some rigidity under speed, against the air flow. You probably don't need the airdam to be even with the lower part of the bumper. Instead all you really need is to keep air from going fully under the car and from crashing straight into the front of the tires.
aerohead (10-29-2013)
