Old 10-29-2013, 03:39 PM   #148 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by HyperMileQC View Post
The IMA switch works perfectly! ... It does in fact deactivate lean burn when you flip the switch while in lean operation.
Do you mean it drops you out of lean burn... but you can get back in nearly right away? That's what mine did.
Congrats on the switch!
The IMA-inhibit / parallel clutch switch was the 2nd most useful switch I put in the U.F.O. after the engine kill switch.
I mounted mine just beneath the radio, so I was able to activate it with my right hand by reaching directly ahead of the shifter.
