Old 01-04-2014, 08:12 PM   #95 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by tvbd56 View Post
I like seeing the things you did to your civic and it gives me a good baseline with mods and ideas to go off of for my 98 civic ex I just wish it wasn't an automatic
Thanks! Your autotrans at least has slightly taller gearing than the EX manual, though (IIRC).
And here are a few more tweaks to existing mods. First is the redo of my upper grill block using some aluminum flashing I had laying around from a fireplace project. Then, second, is a series of pics for the wheel well skirts. The only change is the addition to which are two more clips to each skirt to hold them more snugly against the car. I made the clips from small aluminum mint boxes I had saved to reuse for something.
ID:	14374   Click image for larger version
ID:	14375   Click image for larger version
ID:	14376   Click image for larger version
ID:	14377   Click image for larger version
