Originally Posted by zingaro
u got some good numbers there, man .. .. z
Thanks. The thirty or thirty-five mpg above EPA I generally get is at least half through hypermiling techniques, especially engine off coasting, something I don't think your CRZ can do, or at least I would not recommend it until you very carefully find out if it will wreck whichever transmission it has.Maybe someone on here already knows with certainty and will answer.
The best mods were my tire pressure, airdam, power steering delete (which I doubt you can or should do with your heavier car), injector cut off, alternator on/off, and weight reduction (only because I very militantly cut 250 or so pounds through all kinds of small part deletions and substitutions.
Do you have a fuel log here? Start one up in the garage so we can all track your progress with you!
james
