Old 01-21-2014, 08:19 PM   #56 (permalink)
darcane
darcane's Avatar
Originally Posted by sarguy01 View Post
C128 is on the valve cover.
The only 20 pin connector under the glove box is C145. I posted screen shots from service manual that is actually a 2001, not an 2005. Your manual was not the factory manual, was it?? My setup is probably very close, if not the same, as yours. That yel/blk wire does provide 5 volts to the injectors and the sensors you listed. I will throw up that part of the diagram later tonight.
I think the wire you put a relay on the is one I boxed with red...I studied the pic you posted and the yel/blk wire you cut was the one marked with tape, correct?? It matches the C145 connector.
I have a FSM for 2001-2005 Civics. I was referencing the wiring diagram from Honda that I linked in an earlier post that is specifically 2001-2003. Both of these agreed with each other... but Honda conveniently splits the info up into 100 different diagrams and tables making it quite cumbersome to track down wires. For example, your scan leaves out the immobilizer where as what I was referencing has no mention of the C145 connector.
It's entirely possible you are correct, and I cut the yel/blk wire earlier than I previously thought which would explain my trouble with finding the IGP wires. In which case, those are not as critical as I first thought.
However, it is still critical you don't interrupt the immobilizer since that will require you to key off/key on.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
