Originally Posted by sarguy01
Darcane, I agree that the manual is pretty confusing. Where are all those splices are at is beyond me...
So, here is the 20 pin connector. I have the yel/blk wire separated with the screwdriver. Is this the wire you cut and put the relay on???
Yep, that is the one you want.
I actually snipped it on the other side of that connector. In hindsight, that may not have been the best choice, since you have to disconnect that connection and pull that harness through the firewall to remove the engine. It would have been easier if I snipped it right about where you have your screwdriver.
