So you're saying the outlet would be too perpendicular to the flow around the car? So something similar to the integrated mirror would be better, where the 'ducting' of the mirror channel would force the air to exit more parallel with the flow around the car?
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
