Hrmm. Not a guru and I have a less efficient version civic. I shift at 2k, no later than 2200 unless I have to. I'm at power robbing high altitude as well. It's probably already been said, but isn't lean burn up to 2500RPM depending on throttle position? If you're operating range is 2500-3000 and sometimes 3500...
