Looks fantastic I really like this! I might try to do the same with plexiglass as I can't afford the Lexan
Originally Posted by XYZ
How did you attach it?
1/4" lexan is quite thick a material to use, and not very flexible. I suggest that you try aluminum trim coil, used for trim in siding on houses. It's very easy to cut with snips and it will bend for contours in a grille. It weighs almost nothing, and it won't rust. It's excellent for fabricating belly pans, too.
If you want it to be invisible, simply spray paint it black.
Or the OP can just use what is being shown, without resorting to using house siding that flaps in the wind as it is already cut and mounted? I don't know, I always thought clear is a bit more invisible than an opaque coating
