Old 02-02-2014, 01:27 PM   #26 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by tvbd56 View Post
Thanks for these photos. I have a thought for you to consider. It is possible that these two outer edges are too far out, too close to the outer edge of the tire. When I did mine I saw research for the Prius, second gen I think, that suggested that the outer edge of the spats should be an inch or two inside the outer edge of the tires. It's about how far the airflow gets pushed to the side. You want it to go just far enough to clear the front of the wheel and not so far as to extend the effectual frontal area of the car (via blown out airflow, apparently).
Thanks again,
james
