Old 03-04-2014, 07:15 PM   #3 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
lean burn loves boat tails
Postscript: adding a tail to the VX is extra-brilliant because it effectively expands the "lean burn window" inside which that magical Honda engine gives you astounding cruising fuel economy. You'll be able to hold lean burn at higher speeds, or under other higher load situations like accelerating or climbing.
The gains from a boat tail are greater on a lean-burn equipped car than a conventional one.
