Old 03-04-2014, 03:48 PM   #1 (permalink)
Civic VX Boattail
I may take the plunge... I drive 150 miles a day...
How does this blueprint look? I assume good. Before I begin thinking about fabrication (I teach auto shop, so this will be a fun class project) I just want to make sure that my theory is good.
Name:	Boattail Blueprint.jpg
Old 03-04-2014, 06:12 PM   #2 (permalink)
90 day: 51.82 mpg (US)
Woohoo! Boat tails are so awesome. What an excellent idea to involve the class.
First: The top looks great.
On the bottom, I wouldn't go so "fast". The reason: you're not dealing with clean flow on the bottom of the car as you are on the top, so the angle can't be as extreme. Bottom flow is already turbulent, so more prone to complete separation if you arc away from horizontal too aggressively.
I've tuft tested the bottom surfaces of both my Insight & Metro/Firefly tails, and observed attached flow on both by not exceeding ~13 degrees on the Honda and respecting a much more conservative 6.5 degrees on the Metro/Firefly. (Arguably the Honda has a much cleaner underbody design, which is why I went steeper with it.)
Another critical consideration to keep in mind: the "transitions" from the side to top/bottom surfaces. Use generous radii there, not hard corners, to minimize the chance of "tripping" the flow into vortices.
Old 03-04-2014, 06:15 PM   #3 (permalink)
lean burn loves boat tails
Postscript: adding a tail to the VX is extra-brilliant because it effectively expands the "lean burn window" inside which that magical Honda engine gives you astounding cruising fuel economy. You'll be able to hold lean burn at higher speeds, or under other higher load situations like accelerating or climbing.
The gains from a boat tail are greater on a lean-burn equipped car than a conventional one.
Old 03-04-2014, 07:23 PM   #4 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Well if its all for the children's benefit, you should also have them design and build a full belly pan and rear wheel skirts
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
The Following User Says Thank You to spacemanspif For This Useful Post:
UltArc (03-05-2014)
Old 03-04-2014, 07:31 PM   #5 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
Hi gijoe985,
I say its just fine as its damn near a copy of Basjoos's car.
And heres the proof your overlay on Basjoos.
2000 Insight MT 106K Citrus A/C
Old 03-04-2014, 07:32 PM   #6 (permalink)
Well, we just did an ( overly aggressive) air dam today. As well as a simple warm air intake.
if we came up with a very efficient air dam and side skirt setup, how beneficial would the belly pan be?
Also, what do you guys favor for fabrication material? Abs seems popular. We have thin sheets of stainless. We could possibly fiberglass.
Old 03-04-2014, 07:37 PM   #7 (permalink)
Originally Posted by WD40 View Post
Hi gijoe985,
With respect to the AeroCivic, I'm not convinced the bottom of that tail is optimal. And Mike will tell you he has never tuft tested it. :P
Obviously the tail is "good", but maybe it could be "better".
Well if its all for the children's benefit...
Ha. Yes! Think of the children!
Old 03-04-2014, 07:50 PM   #8 (permalink)
I'll add, discussing the bottom of the boat tail, if we do aggressively block off air from going under the car, how will that affect the bottom of thr boat tail design? Though real world testing will be the final say, I'd like to get as good of a design on paper as ai can before we start building...
then there is the whole practicality factor. I hope to make it so that space is usable. We'll see...
Old 03-04-2014, 07:59 PM   #9 (permalink)
Re: air dams....
You never see a super high-efficiency aerodynamic concept that has a giant air dam. (EV1? Nope. VW 1L cars? Nope. Etc..)
Air dams are band-aids to fix dirty underbodies. Why not smooth out the underbody instead, like AeroCivic, and then you know you're "feeding" relatively clean flow to the bottom of your tail?
I'm not sure what would happen if you put a giant air dam on a boat-tailed car. I never thought to test it out the combination.
Old 03-04-2014, 08:10 PM   #10 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Looking forward to seeing how this develops also! Will be heading up to east Washington state in April, so would enjoy seeing the project first hand if you're in that area.
