Old 03-10-2014, 11:58 AM   #137 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by jedi_sol View Post
Yes. Eoc ing down long hills, making sure to stay out of boost on the pulse. If I do go into slight boost, I'll coast with the engine on for a bit as to not starve the turbo of oil when I kill the engine (i have no proof if this is even an issue, but better safe than sorry)
This is a very good idea on any turbo cars. In fact on the turbo diesel I never shut then engine off during the coast phase. Better safe than sorry.
Nice work! This looks very stealthy but makes a big difference in coast times. I'm surprised more cars don't come this way. I have had a full belly pan for four years and have had no trouble with it even when I got high centered on a snow bank. It just slid right off undamaged. Note to readers in snowy climates. I did have to extend the rear fender liner all the way to the belly pan to seal off around the rear wheels. The first winter snow would blow in there and turn to ice over the course of the winter.
Just a thought. Most tape I have used softens up with heat. You may want to add some self drilling screws around your cat-con.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
jedi_sol (03-10-2014)
