Old 03-16-2014, 01:19 PM   #4 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Best insurance is "copy & paste".
There are a couple of simple solutions, and they're in your hands:
A) When you log in, make sure you check the "REMEMBER ME" box. If you don't, you are subject to time-outs for inactivity. (Note: this may not work with some ISP's even if you check that box.)
B) Before submitting a long post: 1) CTRL-A (select all your text) 2) CTRL-C (copy your post to memory) 3) submit.
If your session has timed out, your post is still in memory and you can begin a new reply and press CTRL-V (paste from memory) into the edit form, then submit it immediately.
These keyboard commands assume you're using a PC. Apple commands are similar, but you'll have to look 'em up.
user removed (03-16-2014)
