Old 03-30-2014, 10:42 PM   #517 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
New fill. 62.xx or so MPG. Late in this tank, I started using higher shift points, as high as 2700 in second, 2500 in third, and 2400 in 4th. I also extensively used DFCO throughout instead of engine off coasting and braking. DFCO was for engine cooling and power generation. I turned the alternator on only during DFCO. The result is the lowest reading on the charger (3.37 kwh ) that I have ever had for a tank. FE was about the same or slightly lower over the last several tanks. The higher shift points might have been the reason for the FE drop, or not. Can't tell.
mikeyjd (03-31-2014)
