02-01-2014, 01:06 AM
#511 (permalink)
Moderator
The Civic is dead; long live the Civic.
Born in September 2004 in East Liberty, OH, as a 2005 model, the Civic lived a long and happy life after being delivered to a dealer in Puyallup, WA, most recently commuting between Champaign and Mattoon, IL where it averaged close to 50mpg. Death came swiftly, in the form of a 24' box truck with a distracted driver. The Civic is survived by a new 2013 Prius. Memorial donations may be made to ExxonMobil.
The Following User Says Thank You to Vman455 For This Useful Post:
02-01-2014, 10:26 AM
#512 (permalink)
Cyborg ECU
Sorry for you loss. Will donations to Costco suffice?
02-01-2014, 10:35 AM
#513 (permalink)
Too busy for gas stations
Turtle - '92 Honda Civic Vx Team Honda 90 day: 67.09 mpg (US) Rolla - '10 Toyota Corolla Le Beast - '91 Chevy V2500 Bus - '01 VW Eurovan MV Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous 90 day: 53.09 mpg (US) Cal - '68 Ford Mustang GT/CS
The pump didn't cut off in time this morning. So, I spilled a lil on the floor for my homies that didn't make it through the war.
Shooting for 600 miles of range at 65-70 mph out of a vx.
02-01-2014, 07:34 PM
#514 (permalink)
I'm assuming no one get hurt??
02-03-2014, 12:42 PM
#515 (permalink)
OK..
1) It's kinda weird that your car was originally sold in my home town.
2) That sucks. 7th gen Civics were the first to get a 5-star crash rating. That's one feature you hope to never put to the test though.
3) Are you OK? How bad was it?
02-06-2014, 01:48 AM
#516 (permalink)
Moderator
I'm fine, thankfully; the trunk was pushed in and there was crumpling in the rear quarter panel/unibody structure, so I'm not too surprised it turned out to be a total loss.
I actually bought the car (used) at Harnish in Puyallup in 2010 while I was teaching at PLU. They got it from Honda of Fife; the claim documents showed the whole history of the car, and it was originally delivered at a Puyallup dealership. And, apparently, involved in a front-end collision before I acquired it.
I've marked it as retired in my garage, but I'll leave it up until the 90-day economy runs out.
03-30-2014, 10:42 PM
#517 (permalink)
Cyborg ECU
New fill. 62.xx or so MPG. Late in this tank, I started using higher shift points, as high as 2700 in second, 2500 in third, and 2400 in 4th. I also extensively used DFCO throughout instead of engine off coasting and braking. DFCO was for engine cooling and power generation. I turned the alternator on only during DFCO. The result is the lowest reading on the charger (3.37 kwh ) that I have ever had for a tank. FE was about the same or slightly lower over the last several tanks. The higher shift points might have been the reason for the FE drop, or not. Can't tell.
03-31-2014, 03:02 PM
#518 (permalink)
Wouldn't the DFCO be the culprit as well? Any time you are using it, your coasting time will go down significantly so I would think it would be far less efficient than using EOC.
03-31-2014, 05:23 PM
#519 (permalink)
Cyborg ECU
Yes that would be true, if I were using it indiscriminately. But I only use it in situations where I will unavoidably encounter excess speed and thus end up braking. In those situations, i have switched from EOC and normal braking to DFCO. Lots of hills ending at traffic lights around here.
04-15-2014, 03:29 PM
#520 (permalink)
Damn.
Looks like I may have bad news to report with my Civic too.
Started getting some high coolant temp readings (205-215°F) so it was time to take off my lower grill block. Pulled it off.
The next day I was still getting the high readings. Popped the hood and coolant had spilled a little out of the reservoir. Let it cool down and the radiator is low.
I'm pretty sure that means it's headgasket time....
