Old 04-13-2014, 10:31 PM   #2 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by DOFZO View Post
I picked up the Auto Meter Vacuum Gauge (2610). I was going to tap into the vacuum line between the PCV valve and the manifold. Is this a good location? Or is there a better line to tap into?
If you *do* tap into the harness that feeds the PCV valve, then several things:
1) keep the tap location close to the intake manifold
2) drill a small .040 inch diameter hole in the harness and tap into that small hole
3) the small hole does two things: keep the flow disturbance to a minimum, allow more air flow to the PCV valve.
4) do not restrict the harness air line to the PCV valve, as this *will* change the tuning to the PCV valve, adversely affecting how the system works.
We make PCV valves at work, so do not take this system lightly.
Jim.
