Old 04-17-2014, 01:36 PM   #20 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Nice. With all that highway, aeromods will help more than a "regular" car...
The more you reduce the load on the engine at speed, the more you can stay in the magical lean burn mode.
Also: are you also manually calculating your MPG on your fuel receipts? Because the UG isn't entirely accurate on a lean-burn engine.
