Originally Posted by MA83
Well, I'm first planning on blocking the front and getting some aero hubcaps. From there I may do an under body tray. I'm a bit of a perfectionist though. So, if I don't think I can make it look good, I'm not sure if I will do it. When I start getting around to it though, I'll definitely be making a build thread. I think I'm going to be doing more air blocking with Lexan though rather than foam and fiberglass. I think that smoky tinted or plastidipped lexan pieces would look pretty sick with the right fitment, and if I do it right I'm going to get them snap clipped into place for easy removal. I'm also planning on getting some of the OEM aftermarket aero parts as well.
Nobody will ever "see" the undertray
I believe the front "grill opening" for the 2014 is relatively flat-ish, so lexan would definitely work.
Im a perfectionist too, hence why I have 3 versions of my grill block!
Have fun with your Subaru!
