Old 05-29-2014, 03:04 PM   #7 (permalink)
oil pan 4
Ok I have one ford 6.0hNo cooler (appears to be the most difficult to hook coolant up to), 2 styles of 2008 to 2010 ym 6.4l coolers. Then some other ones I have not identified, might be LLY duramax coolers.
Shipping will be up to $30, the closer you are to me the cheaper it will be.
If you want one and are in the lower 48 I should be able to let them go for $50 or less each, if you don't need it modified.
Remember I do stainless steel fabrication, so if you need one modified a little I will do it cheaper than any welding or machine shop.
Most of these have 2 bolt flanges to hook up exhaust, coolant hooks up with anywhwere from 1 inch to half inch hose, There are tons of pictures on ebay, I will start listing dimensions here shortly.
I have to put a few on ebay, people are asking stupid amounts of money for used ones on there.
So not only will I supply ecomodders with cheap exhaust heat exchangers I will modify them so you can actually put them on your car sooner rather than later.
