Old 06-14-2014, 10:10 AM   #132 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
It would take 8 of them to hold up a Suburban; they're for the BMW i3.
The I3 is roughly 3000lbs my very old suburban is only about 5500lbs laden on the scale.
There are various sizes available in this tire which is why the actual weight rating would be nice.
[QUOTE=freebeard;429662
You were in the thread in March, have you followed along since? All this back and forth about bumps and energy absorbed by the suspension ignores the fact that a key design feature is using a high-profile aspect ratio so higher pressures can be run.
.[/QUOTE]
Nope, I haven't really followed.
I get the higher pressures but there is a lot more to the tire than higher pressure. Its construction for example is considered novel.
Centerline can make a wheel in any diameter, offset and bolt pattern you require. All the 19x4s have long since left the junkyards, try swap meets.
