There was a Cali and a federal ECU for the HX. Lean burn was still not allowed in Cali, though I understand the first gen insight had lean burn and was it was available in Cali. The easiest way to determine if you have the Cali or the Fed HX is to look at the upstream O2 sensor. 5 wires = Fed (and lean burn) while 4 wires = Cali (and no lean burn).
