Old 06-28-2014, 10:04 PM   #216 (permalink)
jedi_sol
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
underbelly Tray v 2.0 making progress...Rear Tray finished!
Finished up the rear portion of the undertray today.
I slightly modified the rear cross member because it was jutting down 1/4"
I found a piece of left over flat aluminum bar and replaced the bottom piece...its more flat now
I attached the undertray to the rear lower control arm so that it flexes with the suspension
more progress
making cutouts for the exhaust
Almost done
Finished product! The rear undertray angle turned out to be exactly 10*
One slight problem, the revised rear cross member is now a bit too thin, so its sagging under its own weight....will need to support it somehow.
Im thinking using a hose clamp and wrap it around the exhaust and the rear cross member
Next up:
Rear diffuser
Finish Front undertray
Front tire "canoes"
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following User Says Thank You to jedi_sol For This Useful Post:
UltArc (06-28-2014)
