Old 07-11-2014, 01:50 PM   #27 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by WD40 View Post
Hmm seems that heat "may cause" wrinkles.
I think my under the hood temps may be a tad high, that or the location next to the cat on my vx might not be so good.
It did last since 2011, time to replace and relocate.
Wow. I guess you're alright, which is good. FWIW, mine is on the passenger side, toward the engine compartment, between the battery and the intake manifold, above the transmission. It has been there maybe 6 or 8 months without problems. The CAT is probably 900 degrees sometimes, I guess. That's gotta be the issue. I have my build process in my modding thread if you are curious. (See link below.)
EDIT: http://ecomodder.com/forum/showthrea...tml#post412414
It's about 175ci
Cheers, james
