Old 03-03-2009, 07:06 PM   #21 (permalink)
Hi, please help. I can't see the pictures.. thanks.
Old 03-05-2009, 09:20 PM   #22 (permalink)
Polymer - '89 Honda Civic Hatch Std 4 speed
Woodstock - '69 MG Midget 1275
Nekobus - '06 Scion xB
Sorry, I changed my site structure a bit.
They're back up, and thanks for letting me know!!
Old 01-19-2011, 09:39 PM   #23 (permalink)
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
i was thinking why not check your vacuum gauge to see if you can get good braking at half engine vacuum pressure cause if you can get a pressure reducer for your vacuum tank thats at half your engines vacuum pressure then you just doubled your number of braking again??
Old 07-11-2014, 11:14 AM   #24 (permalink)
EcoMod Proof of Concept
WD40's Avatar
WD-40's Insight - '00 Honda Insight
Gen-1 Insights
90 day: 56.04 mpg (US)
WD-40's Mirage - '15 Mitsubushi Mirage ES
90 day: 46.05 mpg (US)
WD-40's Sonata Hybrid - '17 Hyundai Sonata Hybrid Limited
Hmm seems that heat "may cause" wrinkles.
I think my under the hood temps may be a tad high, that or the location next to the cat on my vx might not be so good.
It did last since 2011, time to replace and relocate.
2000 Insight MT 106K Citrus A/C
Old 07-11-2014, 12:45 PM   #25 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Just spend the $40 and get a unit that is designed for the job...
http://www.summitracing.com/parts/sum-g1464/overview/
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 07-11-2014, 01:15 PM   #26 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
the original specs of 2ft by 3in comes out to 170 cubic inches(2.8 liters).
going off of external dimensions of the one from summit, that's 133ci(2.2 liters).
draw whatever conclusions that you would like from that.
Old 07-11-2014, 01:50 PM   #27 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Wow. I guess you're alright, which is good. FWIW, mine is on the passenger side, toward the engine compartment, between the battery and the intake manifold, above the transmission. It has been there maybe 6 or 8 months without problems. The CAT is probably 900 degrees sometimes, I guess. That's gotta be the issue. I have my build process in my modding thread if you are curious. (See link below.)
EDIT: http://ecomodder.com/forum/showthrea...tml#post412414
It's about 175ci
Cheers, james
Building an HPV Fairing trebuchet03 Alternative Transportation 73 01-19-2012 02:50 PM
Woo Vacuum Pump! trebuchet03 The Lounge 10 05-14-2010 12:52 PM
Fiberglass or vacuum molded grill plug? JJW DIY / How-to 2 06-10-2008 01:12 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
DIY: Make a PVC Catch Can for your PCV System TomO DIY / How-to 0 11-14-2007 03:30 PM
