Old 07-13-2014, 03:49 PM   #37 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Your fourth gear is probably about the RPM/MPH range of a 1997 Civic EX. I drop to fourth in some places and in one place then down to third. No problem. Hill climbed. All I am doing is roughly matching what I used to do on the same hills in fourth of fifth with my old transmission. But with the CX/VX trans swap, I also have access to a much taller fifth when I want it for the flats cruising. Just downshift, you'll be fine on them thar hills. But I agree... don't swap a perfectly good HX tranny unless you have to. I only did the swap because I thought I needed urgent rebuilding in my old DX trans. It could use rebuilding, it turns out, but it was never urgent or necessary. I was miss-diagnosing a friction sound I was hearing.
