Old 07-15-2014, 03:23 AM   #17 (permalink)
jedi_sol
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Originally Posted by Baltothewolf View Post
Uhg, if that's the case forget it. I'm to tired to do it right now, I'll figure out how to loop the lines (well, figure out what lines it is I need to loop) and pull everything off at once. I already know for a fact that I want to take it off, as I have tested all the 'sharp' turns I have to take with the engine off, and coasting so, I know I can handle it. Do any of you know a comprehensive guide on how to loop the lines and take off the p/s pump and everything that goes with it?
Under the brake booster on the firewall
There should be 2 rubber hoses that stick out of the firewall (they should lead into the power steering reservoir). This is where you loop the hoses.
However, before you close the loop, then your wheel all the way to the left and right to releases most if the ps fluid. I say "most" because you still want a little fluid for lubrication.
If you don't do this step, there is no room for the fluid to move, thus steering effort will greatly increase.
Then you can start removing the power steering pump, pulley, and reservoir (optional).
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
