Old 08-04-2014, 08:25 PM   #173 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by darcane View Post
I use hand tools for most everything. A 3' long 1/2" breaker bar, with a 3' long pipe over it and another 3' long breaker bar holding the tool in place (it was braced against the ground).
It sure felt like I was about to break something... and then pop, it came loose!
A 150 ft/lbs torque wrench done this way could not get it to budge. A 300 ft/lbs electric torque wrench just failed to do it. I now have an 800 ft/lbs compressed air wrench ... gotta hook that bad boy up. Something's got to give...
Originally Posted by Baltothewolf View Post
Hi Cacivic, what RPM do you see at 70mph with that CX tranny? I'm trying to find out what I will be running with the VX tranny I bought. Also, on your warm air intake, you drilled holes BEFORE the filter right?
I don't know what it turns at 70 mph because I am almost never there except for a momentary pulse under some conditions. Sorry. But for the WAI, my latest version has no drilling. I disconnected the stock tubing at the filter box and replaced it with dryer hose, routed to the exhaust manifold. Simple and effective. I get IAT readings in the 130s and 140s.
aerohead (08-23-2014)
