Old 08-06-2014, 12:19 AM   #1 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Question Stuck timing belt tensioner bolt
For quite a while tonight, instead of finishing the timing belt job now that my epic struggle with the crank pulley belt is done, I have been trying to loosen the tensioner bolt. It is jammed on tight. Spec is 34 ft/lbs torque. I have slightly damaged the bolt using a variety of wrenches and six and twelve point 14mm sockets. I cannot find good answers online... not yet. FSM is not helpful on this point.
I imagine I had better not p-blast such a bolt since it is so close to the timing belt. Can I install the new belt over the old tensioner?
EDIT 1: here is a related discussion on honda-tech.com: http://honda-tech.com/showthread.php?t=199886 ... anyone know these tools?
EDIT 2: http://www.amazon.com/Bolt-Extractors-16-14mm-bolt-extractorw/dp/B00270IMJ2
