Old 08-06-2014, 12:54 PM   #180 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Crank pulley machining, undertray framing
Crank shaft pulley machining
The crank shaft pulley weighs 7lbs (I measured on a scale while holding it, then putting it down and observing the difference). I had thought to have it machined to a single pulley conversion to save weight. I won't be doing that because I'll lose the hex shaped spot for the pulley holder that you need when removing and installing the pulley. Also, there seems to be a rubber "balancer" in the pulley, which would be damaged by machining for a single pulley. The weight loss is not worth it.
Undertray framing
Most of the time I have for the car is taken up with repairs right now... but I did mount the framing under the car, making some spacers from used PVC type pipe.
Progress requires patience.
ID:	15501   Click image for larger version
ID:	15502   Click image for larger version
aerohead (08-23-2014)
