Old 08-23-2014, 06:21 PM   #3 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
You need to determine the diameter of the factory size. Go to tire rack. Com and look up size.
Then look for a diameter about 6-9% larger in a 15" tire. Try not to get too wide.
By increasing the diameter you will improve you mpg because you are lowering you rpm at cruise speeds.
You should really search the tire threads.
There is a lot of info here at econmodder
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
