Old 08-23-2014, 12:55 PM   #1 (permalink)
Arrow Tire and rim recommenations?
I have a 92 civic vx with stock 13" wheels and some kumho tires.
It's time for a tire replacement but since they don't really make 13" tires anymore I'm going to get either 14 or 15" rims. I'm leaning towards 15s because there will be a bigger selection of tires for that size.
As for tires, the most two most important aspects are LRR and quietness. Which ones are best?
Old 08-23-2014, 04:22 PM   #2 (permalink)
Yeah 13s are pretty much a dead rim size. Your only option is Chinese made junk, I don't believe they know the difference between a trailer tire and a DOT passenger vehicle tire.
Same thing is happening to 14s too, most manufacturers are dumping 14.
A few manufactures have even started dropping 15 inch from their lineup. But other wise 15s are going pretty strong.
Old 08-23-2014, 06:21 PM   #3 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
You need to determine the diameter of the factory size. Go to tire rack. Com and look up size.
Then look for a diameter about 6-9% larger in a 15" tire. Try not to get too wide.
By increasing the diameter you will improve you mpg because you are lowering you rpm at cruise speeds.
You should really search the tire threads.
There is a lot of info here at econmodder
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 08-23-2014, 10:45 PM   #4 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Wait. I have 13" VX wheels. I bought 175/70-R13 Michelin Defender low rolling resistance tires for them just last year. Tires are great. Love em. But I did a bit of research on other wheel options in the past and posted some of it in my garage page for reference.
Here are some of the deets:
Possible wheel swaps for gearing/weight advantages:
13" Civic VX 8 spoke (higher RPMs but only 9.7 lbs.)
14" Civic HX 8 spoke (approx 11 lbs)
14" Civic Hybrid 2003-2005 (approx 14 lbs)
15" Mini Cooper R81 Imola 7-hole (12.1 lbs)
15" Mini Cooper R86 star-spoke (15 lbs)
15" Mini Cooper R96 7-spoke (13.8 lbs)
15" Enkei Classic J-speed (14.1 lbs)
15" Enkei RP-F1 (9.5 lb)
15" Kosei K4R (10.7 lb)
15" Konig Helium (11.2 lb) 40mm offset, hub bore 73.1mm
15" Acura Integra GSR (94-95, 16lbs)
Other size specs to double-check for any possible swap: Offset 35-45; bolt pattern 4X100; lug size 12mmX1.5; hub center bore 56.1mm minimum
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
CargoBoatTails (08-24-2014), mcrews (08-24-2014)
Old 08-23-2014, 10:59 PM   #5 (permalink)
Kumho Solus KR21 - Free Delivery Available | TireBuyer.com
Keep the wheels you have and get more kumhos. Pretty light tire.
regards
Mech
Old 08-24-2014, 12:30 AM   #6 (permalink)
I've been wanting Kosei K4Rs or Enkei RPF-1s for a while, can't really justify them on my car which is worth so little but since you're switching anyways I'd go for the Kosei, they're such good bang for the buck at a little over 100 bucks a pop.
I second mcrews suggestion for a taller tire.
The Following User Says Thank You to serialk11r For This Useful Post:
mcrews (08-24-2014)
Old 08-24-2014, 04:56 AM   #7 (permalink)
How quiet are they? I read some reviews and some people say they are really noise and others say they are quiet
The Following User Says Thank You to crz650 For This Useful Post:
Old 08-24-2014, 10:10 AM   #8 (permalink)
Cyborg ECU
Well, I drive a 98 Civic with all of the interior behind the front seats stripped out and I pump the tires to 60psi, so I would not be a good judge of the tires' noise contribution!
mcrews (08-24-2014)
Old 08-24-2014, 01:36 PM   #9 (permalink)
CargoBoatTails's Avatar
If you are worried about ride, going to a bigger wheel is going to hurt you. You can get free shipping and a contracted installation rate from tirebuyer.com. Another thing to consider from the ultra LRR OE tires is tread depth of 8/32 and under is ideal for LRR, so simply finding used LRR tires with a tread depth guage may be a more efficient choice over all, especially if they were a 90k mile tire when new.
http://craigfind.com/classic.html?cx...ind.com%2F&ss=
Glad to help figure out tire sizes for your vehicle.
The Following User Says Thank You to CargoBoatTails For This Useful Post:
California98Civic (08-24-2014)
Old 05-25-2015, 01:00 AM   #10 (permalink)
I also have a Honda Civic VX.
I'm looking to get a set of new tires for my daily driver. I prefer summer tires for maximum grip, etc. only because I'll eventually have a dedicated set of tires & rims for winter. My tire size is 165/70R13.
I'm not sure what I'm looking for. I mostly want to get quieter tires that also still achieve a good MPG.
lrr, rims, tires, wheels
