Old 08-23-2014, 10:45 PM   #4 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Wait. I have 13" VX wheels. I bought 175/70-R13 Michelin Defender low rolling resistance tires for them just last year. Tires are great. Love em. But I did a bit of research on other wheel options in the past and posted some of it in my garage page for reference.
Here are some of the deets:
Possible wheel swaps for gearing/weight advantages:
13" Civic VX 8 spoke (higher RPMs but only 9.7 lbs.)
14" Civic HX 8 spoke (approx 11 lbs)
14" Civic Hybrid 2003-2005 (approx 14 lbs)
15" Mini Cooper R81 Imola 7-hole (12.1 lbs)
15" Mini Cooper R86 star-spoke (15 lbs)
15" Mini Cooper R96 7-spoke (13.8 lbs)
15" Enkei Classic J-speed (14.1 lbs)
15" Enkei RP-F1 (9.5 lb)
15" Kosei K4R (10.7 lb)
15" Konig Helium (11.2 lb) 40mm offset, hub bore 73.1mm
15" Acura Integra GSR (94-95, 16lbs)
Other size specs to double-check for any possible swap: Offset 35-45; bolt pattern 4X100; lug size 12mmX1.5; hub center bore 56.1mm minimum
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
CargoBoatTails (08-24-2014), mcrews (08-24-2014)
