Originally Posted by Daox
So, I was able to find the oil leak... its coming from the head gasket area. ![Frown](/forum/images/smilies/frown.gif) I'm going to double check my head bolt torques, and if thats good I'll probably remove the head again, double check flatnesses and throw a new gasket on. The one that is on there now is from the first time I reinstalled the head and torqued it down to find the stuck valve.
Doh!
I've got mine back together... took it for a quick spin and I'm leaking coolant and oil too. However, I think mine is from the steering rack, which has been leaking for a while and my fix apparantly didn't fix it.
Make sure you get the air pockets out of the coolant. It can be a pain, but you don't want to overheat and have to do the head gasket one more time.
