Old 11-02-2014, 02:32 PM   #138 (permalink)
Ecky
90 day: 84.25 mpg (US)
Wife is complaining about the cold, so I just ordered an OEM block heater from G1parts, part number 08T44-SV4-100. Planning on adding a plug to the front of the car for both the block heater and battery tender (which I confirmed with the manufacturer is safe to leave connected to the battery at all times). Also ordered a fumoto drain valve, and a bunch of random bits the car is missing, things like one of the bolts that holds the glove box on (???), 2 battery box bolts, several plastic clippy thingies for the belly pan, a belly pan bolt, the plastic bits that cover the screws behind the door handles, one of the 3 large screws that hold the trunk latch.
