Old 11-04-2014, 10:35 AM   #3 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
If the leading edges (sides & top) are radiused, then proceed directly to the tapering addition at the rear of the trailer.
I'd make the rear extension as long as possible. The smaller the cross-sectional area where you truncate (assuming you retain attached flow), the better your results.
Then I think, "why bother?" I should just drive 5mph slower and avoid all that work.
Or do both, and double your savings.
