Excellent work as always
one tip to have clean edges when using plastidip...is you have to spray it on a little heavy...then peel off the painters tape while the plastidip is still wet.
otherwise, if you peel off the painters tape after the plastidip has dried...yes, the plastidip will cling to the tape and fray the edges
