Old 11-15-2014, 07:35 PM   #172 (permalink)
jedi_sol
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
What is the Difference between Summer- and Winter-Blend Gasoline? | AAA NewsRoom
The US Environmental Protection Agency (EPA) says conventional summer-blend gasoline contains 1.7 percent more energy than winter-blend gas, which is one reason why gas mileage is slightly better in the summer. However, the summer-blend is also more expensive to produce, and that cost is passed on to the motorist.
The switch between the two fuels happens twice a year, once in the fall (to winter-blend) and again in the spring (to summer-blend). The changeover requires significant work at refineries, so oil companies schedule their maintenance for those times when they will already be “down” for the blend switches.]
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following User Says Thank You to jedi_sol For This Useful Post:
OG VX (11-17-2014)
