Old 01-04-2015, 08:55 PM   #15 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Let me get this straight:
Injector HOT (yellow wires, on the side running away from the injectors from the relay) should be tied together and connected to #30 and #85 on the relay.
Injector COLD (yellow wires, going TO injectors from relay) should be tied together and connected to #87a on the relay.
Kill switch should be connected to #86 (blue) and grounded to the chassis.
#87 on the relay should be grounded to the chassis.
You ran two wires into the cabin. Am I right in thinking that's unnecessary? That is, it's fine to ground the switch near the steering column?
If I understand this correctly, is it safe to be grounding the constant-on power for the injectors? It's not a short? Would it have been better, though much more complicated, to relay the grounds to the injectors?
EDIT: Also, cowmeat provided me a fuse. If I were to guess, it probably goes between #87 and the chassis. Is this right?
EDIT2: Seems to me the short-circuit problem could be solved by swapping #87a and #30, because when the relay is activated, the connection is broken but the injector HOT isn't grounded.
KFM (05-02-2017)
