Old 01-11-2015, 10:16 PM   #11 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Originally Posted by Number21 View Post
Would I be correct that a setup like this would offer worse mileage on the highway than the same size engine directly connected to the wheels through a transmission? I'm going to be moving way out into the country soon and I need a vehicle that can get me to town on minimum fuel.
I found this plugin hybrid powertrain setup from Via, they claim 100mpg on a little bit lighter vehicle, but that's with a gas engine!
Extended Range Electric Powertrain Trucks, Vans & SUVs-EREVS | VIA Motors
I'm thinking my best option might be a combination of a smaller engine, BAS, and front wheel electric drive. The advantage of having 4WD would be nice. Anybody know how much my extra kidney is worth?
Not sure. The Accord hybrid is rated 50 city / 45 highway, and has ~200hp / 225ft lbs to the wheels.
Running serial might be better if you don't pulse and glide under normal driving conditions, because that's basically what the engine does while cruising at a constant speed (or should do). Direct drive P&G at a given engine size would almost certainly be more efficient.
