Old 01-14-2015, 12:50 PM   #20 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
I'm hoping to be able to pull about 1000lbs in my Insight and would be surprised if I got less than 60mpg on the highway while hauling. For 4400lbs you're almost certainly going to need a truck though.
Ideally, I'd probably start with an older 5MT Tacoma and build a gull-wing topper. Lower it a bit, keep tire pressure up, air dam and adjustable grille block. Smooth wheel covers, rear skirts, and some paneling on the underside. You wouldn't have the advantage of being able to drive around on just electricity, but the cost:benefit would probably be better.
