Old 01-14-2015, 07:17 PM   #26 (permalink)
mikeyjd
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Originally Posted by BamZipPow View Post
Since you have the grip handles on the A pillar, you could easily make a bracket that could be fastened to the lower bolt that would allow the mirror arm to be mounted to. Don't be afraid to take the unit apart.
I adjusted things a bit more and zip tied the mirror to the handle for better rigidity. I calculated about 30' is when traffic appears in the driver side.
Originally Posted by Baltothewolf View Post
Nobody really answered this, but could you remove your outside sideview mirrors and replace them with these on the inside?
I would say on a vehicle where you will be using a trailer that it would not be advisable to do so. I would not want to be without the option of my regular mirrors if I had a full load in back and a 12' trailer attached. I would say they are good enough for cruising around with though, especially if you have any kind of rear view mirror. You will have to try it and see what you're comfortable with, and what suits your personal needs though
The Following User Says Thank You to mikeyjd For This Useful Post:
BamZipPow (01-14-2015)
