Old 01-14-2015, 02:35 PM   #21 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Originally Posted by kafer65 View Post
It comes with an adjustable plastic angle iron bracket with two sided tape on one facet of the bracket and the punch out holes for locking the sliding adjustment for the mirror arm on the other facet. BAMzipPow just removed the adjustable mounting to mount the arm directlyon the A-pillar.
Just picked up one and I really like it. I'm gonna pick up one for the other side on the way home
The Following User Says Thank You to mikeyjd For This Useful Post:
BamZipPow (01-14-2015)
Old 01-14-2015, 02:40 PM   #22 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
Originally Posted by HiFlite View Post
Hopefully you don't have airbags deploying from the A-pillar. That's a lot of hardware to come flying back at 100 mph.
I found several references to mounting gauges and such on the A-pillar panel and mounting on the lower third to avoid the curtain bags in there. The panels are held by spring clips. The bags seem to be designed to push the panels out of the spring clip holds when deployed. I may try clamping to the panel on the passenger side instead of mounting through it on mine. Maybe a longer gooseneck stem to get the mirror closer to the side glass.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
The Following User Says Thank You to kafer65 For This Useful Post:
Old 01-14-2015, 06:07 PM   #23 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
Originally Posted by mikeyjd View Post
Could you please expound upon how you mounted the passenger side interior mirror? Does it come with the mounting bracket?
I took the mounting system apart and mounted it through the A pillar trim. I pulled the trim off to see what I could mount it to in case there was a threaded nut I could use to mount a bracket to and then mount the mirror arm to that. I ended up marking and then screwing the arm into the A pillar trim.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (01-14-2015)
Old 01-14-2015, 06:09 PM   #24 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Since you have the grip handles on the A pillar, you could easily make a bracket that could be fastened to the lower bolt that would allow the mirror arm to be mounted to. Don't be afraid to take the unit apart.
Old 01-14-2015, 06:11 PM   #25 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Nobody really answered this, but could you remove your outside sideview mirrors and replace them with these on the inside?
The Following User Says Thank You to Baltothewolf For This Useful Post:
Old 01-14-2015, 06:17 PM   #26 (permalink)
mikeyjd's Avatar
Team Ford
Team Dodge
Pickups
I adjusted things a bit more and zip tied the mirror to the handle for better rigidity. I calculated about 30' is when traffic appears in the driver side.
I would say on a vehicle where you will be using a trailer that it would not be advisable to do so. I would not want to be without the option of my regular mirrors if I had a full load in back and a 12' trailer attached. I would say they are good enough for cruising around with though, especially if you have any kind of rear view mirror. You will have to try it and see what you're comfortable with, and what suits your personal needs though
Old 01-14-2015, 06:17 PM   #27 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
I guess it depends on how much you depend on yer mirror angle of view. By removing the outside mirrors and just using the blind spot mirror to see rearward, you will miss out on the view along side yer vehicle and back. Because the exterior mirror is outside, it provides that angle of view that the interior blind spot mirror can never achieve. I personally didn't feel comfortable with the outside mirror (folded in in my case) view missing especially when I was trying to back up.
Old 01-14-2015, 06:19 PM   #28 (permalink)
replace
Not legally.So far,'other' mirrors are replacing OEM units with some members,and they're augmenting these with interior units for added safety.
You need to know your driving environment at all times.Saving fuel isn't worth your property,that of others,and health/life.
BamZipPow (01-14-2015), freebeard (01-14-2015)
Old 01-14-2015, 08:58 PM   #29 (permalink)
"Situational awareness"
BamZipPow (01-15-2015)
Old 01-14-2015, 10:14 PM   #30 (permalink)
Furry Furfag
I completely agree. When I asked the question, I meant are they suitable replacements for outside mirrors, hence why I didn't ask if it was legal or not :P.
Now that I see the responses, I'll take that as a no.
