Old 02-01-2015, 04:56 PM   #207 (permalink)
vrmouseyd15b
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
Also got the EOC Kill Switch done last night. Found the PGM-FI main relay (above the hood release handle, kinda) - The internets were right - It's in a terrible spot to get to.
So here, I found the relay and consulted Gasoline Fumes' post again for the wire in question. once I thought I had the right wire, I (temp) mounted the switch right there to double-check myself..
Thanks again, Gasoline Fumes - one shot, one kill
That meant it was time to mount the switch. I took a blank from next to the ignition and chewed on it until it took the switch. Then more solder and heat shrink tubing (ugly pic)..
Then It just popped right in place! I'ts got a kinda cool, almost industrial look to it. The switch itself is heavy for the little thing it is, and takes a good firm push. definitely feels like a better quality switch than the one in the Minion..
So that's done! one more thanks to Gasoline Fumes
Thanks,
Victor
