Old 02-19-2015, 11:24 AM   #123 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
... I read http://ecomodder.com/forum/showthrea...vic-18242.html and it specifies NO, but not amps. ...
Fwiw, I think my switch, which you refer to above, is called a NC or normally closed switch, because it's normal position is to close the circuit and allow current, pushing the button "opens" or breaks the circuit. As for amps, there are none to consider, if I understand correctly, because I cut the ground wire only. A reason for that was concern that fraying of the insulator miht eventually allow current to make contact with the metal shifter.
